I purchased the steel parts for my Partol wing from Mark at AviPro. I chose them to be unpainted. They were protected with a rust protective coating of some type (feels similar to boeshield). Any recommendations on what to clean it up with before I paint.
Painting steel parts
John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uwTags: None
The parts are already sandblasted. acetone seemed to work well. thanks.John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
I use Naptha to clean everything to painted. It leaves no residue and cleans, degreases thoroughly. Use a two papertowel system, one wet with Naptha and follow up with a dry one. Steel parts get sandblasted. I like a 2-part epoxy primer and then top coat with a urethane enamel paint. A couple of light coats of each is sufficient.
Eric and Others,
Your comment and Bobs note in the plans brings up a question. You said that you use a 2 part epoxy primer than a urethane enamel top coat on the steel parts. For the internal wing parts is the top coat really necessary. I am using AkzoNobel 2 part solvent based aircraft epoxy primer that when dry is impervious to about everything including MEK. Are there reasons that with this primer I would also need to top coat the internal parts? Thoughts folks?John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
Nope!
The epoxy primers are pretty bullet proof. The urethane topcoat is really just for looks. In issue in the visible parts of the fuse. The urethane is also easy to clean (slick). compared to the primer surface.David Edgemon RV-9A N42DE flying RV-8 N48DE flying Patrol #232 N553DE in progress ! Plans built.
Might be I just put it on too thin but I used epoxy primer only on my internal steelers parts on the Bearhawk and a couple of years later found some surface rust. Make sure you get enough of it on to totally seal the part. Eric Newton - Long Beach, MS http://mybearhawk.com
Steel not steelers - dang auto correct got me again. Eric Newton - Long Beach, MS http://mybearhawk.com
I used a two part epoxy primer (PolyFiber EP-420). Bullet proof... No top coat. A light misting coat is OK for aluminum parts, but not so with the steel. On the fuselage, I used two coats, make sure it is covered real good. Don't want no rust...
Collin Campbell, (Bearhawk N370CC, Patrol, N180PB)
Bolivar, MO
Does anyone know if it is OK to prime blued//black oxidized steel without getting back down to the completely bared metal? Let's say you've either sandblasted or sandpapered your steel down a perfectly clean metal surface, then tig-welded on a fitting or for some other reason had to seriously heat the steel in the neighborhood. The recently spotless steel now has a patina like that of a brand-new shotgun .... beautiful shiny blue/black. Getting the area back down to bare metal again is time consuming. Since the blued finish is so good at preventing corrosion on a shotgun, it should be good enough on a Bearhawk too. Right? For that matter... when sandblasting, is it OK to stop eroding away the tubing when all that remains on the tubing surface is a microscopically thin transparent shotgun-like blued surface?Last edited by bergy; 06-14-2019, 09:47 AM.
The best source for an answer to your question is to get the recommendations from the manufacturer of the paint you plan to use.
There are chemical etching solutions designed for steels as a preparation prior to priming. I use PPG products and they have detailed instructions for surface preparation for their automotive/aircraft finished.
Originally posted by bergy View PostDoes anyone know if it is OK to prime blued//black oxidized steel without getting back down to the completely bared metal? Let's say you've either sandblasted or sandpapered your steel down a perfectly clean metal surface, then tig-welded on a fitting or for some other reason had to seriously heat the steel in the neighborhood. The recently spotless steel now has a patina like that of a brand-new shotgun .... beautiful shiny blue/black. Getting the area back down to bare metal again is time consuming. Since the blued finish is so good at preventing corrosion on a shotgun, it should be good enough on a Bearhawk too. Right? For that matter... when sandblasting, is it OK to stop eroding away the tubing when all that remains on the tubing surface is a microscopically thin transparent shotgun-like blued surface?
