Aileron/Flap Gust Locks
Thanks Paul,
Another great idea I can steal for my Bearhawk. Just recently went over the 600 hr mark on my Bearhawk. Gets better and better.
- Likes 3
Leave a comment:
Hey All...
I want to share what I made for the 4-place BH. Yes, they look almost identical to the Atlee Dodge gust locks because that's where I got the idea from. I would have bought them from Atlee, but I wasn't sure if the profile angle of the Piper aileron/flap matched the angle of the BH control surfaces. Also, the bungees holding the Atlee locks in place wrap around the lift strut of the Piper. That isn't an option for the BH as the lift strut is way out of alignment with the aileron/flap intersection. I looked at ways to attach a bungee and almost settled on drilling a hole in the bottom of the wing somewhere close to the edge and installing a small eye bolt. I spent a lot of time just thinking about options when saw a little hole in the wing that is created by a stiffener that is riveted to the trailing edge of the flap pocket. I tried out different diameters and lengths of rods and found one that slid in and out without any trouble.
I made the pins and the eyes welded to the end of the pins out of stainless steel so they wouldn't rust. I made the locks themselves out of some scrap .060 5052 that I had in my now vacant shop and glued some neoprene strips on the surfaces that contact the fabric. A couple of red bungees, flagging and some zip ties later I have a set of gust locks!
I have a set of Air Gizmos gust locks that I was using for the flaps, but I had to still tie the stick back. Also, there were a couple of times I found the gust lock on the ground when it had worked itself loose. The Air Gizmo lock works great as long as the surfaces are close to parallel. So instead of buying another set for the elevator, I made these and am now using the ones I had for the flaps on the elevator. Now everything is tight and I don't have to use the seat belt to tie the stick back. YMMV
20240730_170658.jpg 20240730_170637.jpg 20240730_170611.jpg 20240730_170628.jpg 20240730_170110.jpg 20240730_170525.jpg 20240730_170519.jpg 20240730_170040.jpgTags: None
- Likes 12
Leave a comment:
