Finishing up my rear spars and have come across an issue regarding the placement of the cove rib aft of center rib #14. I'm confident I've located the outboard aileron hinge centerline on the spar web correctly. I'm also confident that I have center rib #14 located correctly. However the distance from the outboard edge of the center rib #14's flange to the aileron hinge centerline should be 1.375. I measure 1.75. Ref sheet #2, the wing assembly drawing shows center rib #14 and the cove rib aft of it. The webs of the center rib and the cove rib are planer. I don't know where I've gone wrong. Checked everything over and over, still come up with the same answer. All the other measurements on the spar have checked out so I'm missing something. I have center rib #14's flange pointing outboard, the center rib attach angle flange common to the spar web is pointing outboard. Doesn't matter much if I install the rib on the inboard or outboard side of the attach angle, I'm still to far inboard of the hinge center line. Has anybody here had this issue.
Thanks
Patrol #30 wings
Thanks
Patrol #30 wings
