Stabilizer Streamline Strut Vibrations
We first encountered the issues with smaller tires fitted, Goodyear "26s" (which are really 23 inches tall)
I've searched and can't find the thread that covers your strut break and engineering change. Do you have a link?
I wonder if big tires throw more turbulence back to the tail?Last edited by Craig Van Sickle; 02-03-2022, 11:36 PM.
I have also had issues with the streamlined flying wires hitting resonance, they vibrate a lot and you will never know unless you look back when the elevator is unloaded (hands free). You can change the resonant frequency by changing the tension in the wires (I suggest lower, not higher).
Leave a comment:
Mine also broke in flight, there is a different post about that plus and engineering change which fixed the issue.
The beauty of the design is the tail system has redundancy, so wires or struts failing is not a problem.
I would love for someone to put together a Beartracks article about it.
I think mine broke because of corrosion rather than resonance
Correct me if I'm wrong, but I remember some time ago Jared caught an issue during an inspection/preflight on this tail strut? I did a search but didn't find the thread, just wondering out loud if this is related?
Higher time and/or bush fliers seeing any issues?
Andy
Leave a comment:
This thread might be important enough safety-wise to put somewhere that all builders see it at some point. Maybe a Beartracks article? Sticky in one of the forum categories, like the current one?
Leave a comment:
While I have no knowledge about this and no expertise - I kind of suspect just one strip in the middle might break up the harmonic vibration. But someone would need to try. Mark
Nev, I think you are referring to the 4 place. The Patrol strut is formed and drilled at each end so no threads.
Mark, Mike Silvernagle mentioned making 6 strips so that's what I used pr side. He may have only added three a side. Unclear on that whether he attached the six to the one strut that was vibrating or three to each.
Mike wrote:
" I ended up cutting 6 pieces of 1/4" wide strips of velcro 1" long and sticking them to the underside of the 4130 streamlined tubing"
If the weather was warmer and I had the opportunity to play with the strips, I'd see what the minimum would be to eliminate the vibration.
Thanks for the feed back guys.
Leave a comment:
Thanks for posting this Steve. You put more velcro strips than I imagined. I wonder if fewer strips would accomplish the same thing? Maybe someone will play with it and answer this question. Mark
Leave a comment:
Good to see you got it sorted. I was wondering if that could be the cause of fatigue issues on the threaded portion inboard, if the vibration is left to continue.
Leave a comment:
Picture of the velcro strips used to stop vibration
Leave a comment:
Leave a comment:
