This appears to be a slight variation on a simple dipole antenna, which works well in wooden and fiberglass airplanes. They are cheap to make, about 2 or 3 dollars for materials. For optimum performance in com usage, the antenna should be oriented as near vertical as possible since uhf com signals are vertically polarized. I have used two (that I made myself) in my Maranda (wood and fabric) for years with excellent results. Jim Weir used to have a booklet that gave easy-to-follow instructions on making dipole antennas for com, VOR, FM, etc; but, you can probably find the same info on the web. Weir does not recommend them for installation inside metal-framed or aluminum-skinned structures. For that reason I am using exterior 1/4 wave antennas for my 4-place.
