huntaero
4 Pl BHK scratch build
Fitted 2870 floats to my Bearhawk used the older style 249-2870 with the swivel attachments, all the struts had corrosion under the clamp on steps so I purchased new struts blanks from Southern aero in Georgia Products (southernaero.net) PN LS-4. Attached are a couple pics of my set up and the ventral fin I fabricated and attached to the tailwheel mount and fwd mount of 4130 sheet welded across the bottom tube at the fwd end, with a tie down handle to maneuver the aircraft on a beach. I used the Edo rule and went 40% of the widest part of the float which is 12.04 inches aft of the center C of G to the step or 28.5 inches aft of datum. The 2 fwd struts remain the same length and my step was within ¼ of the 40%. I set my angle from the top of the floats to bottom of the wing at 3.5 degrees and if not enough I can shorten the aft strut by ¾ in without much work, and get about 0.7 more degrees to put it at 4.2. Fabricated my fwd strut attach fittings from 2024 alum. I fabricated new rear attach fittings from 4130 and used the original cross brace wires on the aft but needed shorter ones for the front which my buddy had for a set of 2425 floats. Fabricated my sling also to pickup on the fwd spar attach bolt and the L and R upper eng mount bolts.
