Thanks Terry, I was on the Aerosplat website just yesterday, so good timing. I really like the Aerosplat concept, and having a simple Open/Closed switch. It'd work well on the oil cooler butterfly valve too.
Is that an air scoop on the top cowl - and if it is, I was curious if you found it helped with cooling ? I couldn't tell from the photo where it sat in relation to the high/low pressure compartment.
