Astro John
Following the new wing build manuals, I drilled out the holes in the inner 2 ribs for the fuel lines.
The holes for the 3/8" lines get drilled to 5/8" and the 1/4" lines get a 7/16" hole, and then grommets are used.
There is very little room if you didn't get the holes perfectly drilled. Two of mine are spot on, but the other two could use a little bit of wiggle room.
I am thinking about upsizing the holes, and then using a combination of tygon tubing and a larger grommet. I would only need to do the inner rib.
Sound reasonable?
Sound reasonable?
