For perspective, I measured some spar part thicknesses before and after priming. Spar web before .0321 after .0338, capstrip before .1247 after .1257, spacer bar before .0618 after .0631. Other parts were similar The spar web primer is too thick but I did the best I could with what I had. I used an airbrush, painted outside in the summer. With what I know now, I could have done a little better but I'm satisfied the parts are well protected in a salt environment. If you can do better with a brush have at it. Primer is Stits EP-420. I used about a quart and 1/4 or so for all the AL wing parts less the ribs, rib stiffeners and skins. I used the standard Bonderite C-IC 33 etch and Alodine 1201 prep. Not sure how brushed fay surfaces would work out. Good luck.
Gerry
Patrol #30
