We have two Patrols under construction and wrapped primary welding on both fuselages this past November. I suspect the Companion is pretty similar to the Patrol, so here's what I did:
- Using the VR3 Patrol Seaplane version of the fuse tubing kit doc, I cut and pasted the tube data (which includes length) into an Excel spreadsheet
- Usual 'tubes times number x length' to come up with trimmed gross tube length, then multiply by 25% to get actual 'buy this' length.
You will have to adjust lengths based on the plan's flat layouts for the top and bottom, but sides may just be a case of verifying tube diameter and placement... a bit of a shortcut versus developing the full cutting list. Unfortunately the Patrol Seaplane kit is the only full fuse list with tubing lengths, so some work to be done on tail feather, landing gear, and engine mount.
Have heard the the VR3 tubing kits are well fitted, but have not had the chance to see a tubing kit close-up. Lots of time coping tubing might make that additional cost worth it, but also less fun if you actually like scratch building.
