I am in the process of mounting Garmin a/p servos. Pitch was fairly straightforward. However, It seems like there is more left-right travel than the roll servo will allow. With the optional longer crank arm, the servo is limited to about 2.9 inches. When I measure the travel at the bottom of the stick, it appears to be about 3.4 inches. However, I do not have my wings and ailerons attached. So now I am wondering if I am seeing more range of motion in the sticks than I will once they are connected to the ailerons. I'd really appreciate it if someone could maybe measure at the bottom of the stick the full travel of the shackle bolt in full deflection left-right. Thanks!
Left to Right Stick Travel
