Mark Goldberg
Bearhawk Aircraft
A customer in Australia had his first flights in his new four place BH in the last few days. It has a Bob Barrows 540 and two blade Hartzell metal prop. Reports of the flights are good.
Paul intends to use his BH for glider towing as he is a competition glider pilot. Look at the tail spring & tow hook
. I asked Paul what the empty weight is. Here is his response:
675kg. Tow connector does work well with round rod. It was designed and created by an engineer on the Raaf base so I can’t claim any credit. We are planning to tow up to 1000kg in 1 or dual (2gliders at once). Night VFR rated - would just need to upgrade gps for IFR. It has 3 batteries, dcdc isolation of essential bus, 2 earthx (1200 and 680) and smaller lead acid battery so a little extra weight here but lots of redundancy for night flying.
. I asked Paul what the empty weight is. Here is his response:675kg. Tow connector does work well with round rod. It was designed and created by an engineer on the Raaf base so I can’t claim any credit. We are planning to tow up to 1000kg in 1 or dual (2gliders at once). Night VFR rated - would just need to upgrade gps for IFR. It has 3 batteries, dcdc isolation of essential bus, 2 earthx (1200 and 680) and smaller lead acid battery so a little extra weight here but lots of redundancy for night flying.
