Thanks for the report. Any ideas on having to put 50 lbs. in the back to get close to spec speeds? Elevator travel? Angle of incidence, wing and horizontal stab? I went back to your website and reread your W&B, looks good. BTW what do you weigh, I'm 240 but with the pilot seat at 10" that's not going to effect much. Hopefully just a few tweaks in the test flying stage.
Doug
Edit:
After second thought on W&B, your empty CG is 12.88 so with the pilot a 10" a heavier pilot will make it slightly worse, but not by much. I put my 240 lbs. in your W&B and moved the CG about half an inch forward.
Doug
Edit:
