Ready to put on the last bottom skin on but have not put the full length tip rib in place because the rigid method in which I have the spars captured and accurately aligned will not allow the full length rib to be installed. How has everyone handled the tip rib or if you did, how did you hold the spars accurately? Did you leave it full length? Thanks.
Full size tip rib
Sounds like you may have used a different method to assemble your wings than what is "typical" for the type. Can you provide photos of your setup?
While this is for the 4-place, here's an overview of how one would assemble the wing set up in a vertical jig. As you can see, the full-sized rib is already attached before assembling the rest:
If yours is the QB wing, I would have presume that the end rib would have already been installed.
~ChrisLast edited by Chris In Wisconsin; 09-01-2017, 12:30 PM.Christopher Owens
Northwest, Wisconsin, USA
Your photos helped a lot. I am building the LSA plans built and I used the same parts to align and hold the spars accurately and rigid that I used when I built my RV-4 plans built. I have figured out what I have to do with the help of your pictures to get the tip rib on. Thanks.
Looking forward to the day I get to that spot in my build!
