My goal is to build an LSA (including an electrical system/starter) with useful of 500lb or greater. From watching/reading the information on the BH LSA, I believe this is doable. I've read that adding electrics and starter to the C-85-12 will add between 45-60 lb. So, Bob's comment that builders can keep the aircraft at 750+ adhering to building light principles and adding the 45-60 for the electrical system - looks doable.
Thoughts...
Wants:
1. Minimal VFR panel
2. Transponder
3. Starter if I an stay below 820 empty.
4. GPS and Com will be portables.
Some of the options/items that make the BH LSA a leader on my list:
Thoughts...
Wants:
2. Transponder
- Plans only option.
- STOL aircraft. Want the option to keep the aircraft in my backyard in the future.
- Decent cruise speed north of 100 mph for those short cross-country trips.
- Low stall speed.
- Simple design. Impressed with the 30mph stall without the need for flaps.
- All metal wing. Not a fan of fabric wings.
- I want at least 500lb useful. From what I’ve read, I should be able to keep the BH LSA below 820 lb empty even with an O-200 with starter/electrical system.
- Prefer a tri-gear, however would rather have a tandem if limited to tail dragger configuration.
