Rivet Calculator
  • Rivet Calculator
    Hey guys. I’ve been waiting for my aluminum delivery and diving into everything. Since I’m new to a lot of these skills, I’m creating cheat sheets. I created this rivet cheat sheet and rivet length calculator. I don’t doubt that it already exists, but I learn by creating things like this so it was a good exercise for me.
    While it isn’t complete, I think it’s a good start. Hopefully someone else finds it helpful.
    I ended up cutting rivets to actual length after experimenting with test coupons and recording the results. I found that rivets cut to my calulated length were consistantly short and gave me an undersized shop head. Making test coupons was my salvation. I did not want to drill out a -5 rivet and I didn't have to.
    I remember only a couple of locations on the spars where a stock rivet length worked, all the rest were custom cut. Just my method, yours may vary. Your spreadsheet will give you a good starting point. Good luck.
    Gerry
    Patrol #30
      They never sell them in every size you want
      What you want to do is invest time to make something like desertbearhawk
      desert bearhawk video
      https://www.youtube.com/watch?v=ypn5WkxUDQM
      I did something stupid:
      Under no circumstance buy or use
      If you were Boeing they probably would sell rivets in 1/4 and 1/2 size.
      Wrong size rivets will anvil over making extra work which can be avoided by cutting each rivet to the correct size.
      Then again if you worked for Boeing driving rivets all day you might be able to drive the wrong length rivet -- but I doubt it.
      If cutting each rivet to size seems like a lot of work then compare it to drilling out each rivet you anvil over.
      Stan
      Austin Tx
        Au contraire, I found the rivet cutter to be invaluable, along with shims to get in between sizes.
        Frank Forney
        Englewood CO
        EAA Chapter 301
          I remember from Star Trek where Scotty says "fool me once, shame on you; fool me twice, shame on me"
          I wish that stupid thing only ruined two rivets, before I chucked it.
          I am pretty stupid and I have a jar of rivets I had to drill out.
          Stan
          Austin Tx
            They don't come much stupider than me. Early days in my collection of drill-outs, easily twice this many by now.
            Nothing to do with the rivet cutter, though.
            Frank Forney
            Englewood CO
            EAA Chapter 301
            • sjt
              sjt commented
              Frank, you are missing an opportunity. Blame it on the rivet cutter. No one will know.
            I can't seem to download your rivet calculator however I'm curious how my "as installed"' rivet lengths compare with your calculated length. The most common 5/32 rivet used in the fwd wing spar fastens 4 .125 thick capstrips and a .032 web. Calculated material thickness is .532, actual measured thickness with primer is .539. Per table 4 of MIL-R-47196A, I am shooting for a shop head diameter equal to or greater then .203 and a height of .077, which put me in the middle of the shop head thickness tolerance range. To get there, I had to cut my rivets to .740. How does that compare? Add 2 .032 attach angles, my as installed length is .808.
            Thanks
            Gerry
