Max baggage weight for the LSA
  • Max baggage weight for the LSA
    Can anyone tell me the maximum baggage weight for an LSA that weighs 775 empty, pilot weight of 190, passenger weight of 130 with full fuel of 180 lbs? I'm not LSA limited at 1320 lbs and would/could, use up to the allowable 1500 pound max gross
    I'm assuming you are asking what is the max baggage compartment load based on C.G. limits? (There is no max baggage compartment limit other than C.G.) For the numbers you listed you are starting to bump aft C.G. with 80 lbs in the aft baggage compartment for a gross weight of 1,355 lbs.
    Wayne Massey - Central Florida
    BH733
    LSA23
    http://www.mykitlog.com/wlmassey
      Thank you Wayne, that is the information I was looking for
