Making some progress on Ribs
  • Making some progress on Ribs
    Well I have been able to kale some progress on my wing ribs. I have formed all of the nose ribs and aileron nose ribs. I have also cut out all of the center ribs. That created a big pile of silver sawdust. I was originally cutting out the rib blanks with a Delta router/shaper table that I had. I was getting excessive chattering with it. I switched to using a variable speed router to a homemade router table. I was getting superior results. I am using a 1/2" solid carbide spiral bit for the main parts and a 1/4" solid carbide for the aileron nose ribs. I had very good success here. I also cut out the lightening holes with the router.
    For the aileron nose ribs I used the rubber pad with the 20 ton press. I made a forming jig and undercut the sides about 8deg to account for springback. It worked perfectly. The ribs came out with perfect 90deg bends and good bend radius. I used the same process that I showed on a video I posted here a few weeks ago. The only addition I used was that I sprayed lemon pledge on the piece to act as a lubricant as they did on the EAA video. Side effect was that it made the shop smell better. Take a look at the results below.
    This gallery has 3 photos.
    Looking good!
    I was able to get all my .025 center ribs, end ribs and angle stiffners aliodined yesterday. Can't wait to start working on my spars.
      Looks great. I went back to watch your video of the rubber press process and it was gone, the thread was there but not the video. Also do you have a link for the EAA video you talked about? I am interested to find out about the rubber, what durometer and a good cheap place to find it.
      Doug
      Scratch building Patrol #254
        Doug
        Here is the link for the video I did. I have also included the link for the EAA video. You may have to log in. It is in the video section and if you search for "hydro" you will find it.
          Thanks, I had watched it a couple times when you first posted it but went back and it was gone. I had not seen the EAA one, Thanks. This is the coolest tip to come along in a long time. I already have a 50 ton press, but it is Armstrong powered. Oh well a little exercise won't hurt me. Thanks for bringing this to our forum.
          Doug
