Finished the aft ribs and started pre-drilling the center ribs for routing.
New band saw blade made for easy trimming of the excess aluminum. Although using a narrow blade is a stinker because it tends to wander. Perhaps some more tension is in order.
![](http://uploads.tapatalk-cdn.com/20160204/b5b7850a60157d87819cf6412aedf5f0.jpg)
Got them in the router table, and life is good.
![](http://uploads.tapatalk-cdn.com/20160204/f375a201172297189ef8006ac33cb4e2.jpg)
Had some more helpers in the shop tonight, doing a fine job with the drill press, as well as general supervision of events (guess which ones are the supervisors).
![](http://uploads.tapatalk-cdn.com/20160204/4a825303dd966a65b9f100d7ff1d02e0.jpg)
![](http://uploads.tapatalk-cdn.com/20160204/f2d403c806f30e6bc341cfba25805e6b.jpg)
Now all the centers are drilled and ready for routing:
![](http://uploads.tapatalk-cdn.com/20160204/bc3aad2b2e82107ccf54bae1b2d604c5.jpg)
![](http://uploads.tapatalk-cdn.com/20160204/9fa8049ad640cb93988344039fe0fb96.jpg)
Have to be mindful, though. The .032" ribs have different aft lightening holes than the .025" ones. There's a separate jig/pattern for that hole. Don't screw up!
