Does anyone have a material list for wing construction? I am about done with forms and want to make an order. Thanks!
Patrol wing material list?
Don't know of one for the patrol but Lynn Riggs did a comprehensive job on the 4 place materials. I'm going to try attaching the spreadsheet here as I don't think you can access it on the old group site.
Can't do it sorry, gives me an invalid file error! try emailing me if you want it:
benbowc@attglobal.net
Craig
Look down in this section I have all the ribs nested out. http://bearhawkforums.com/forum/bear...esting-layouts Basically you can fit all the ribs on 3sheets of 4x12' .025 and 1 sheet of 4x12 of .032 of that one sheet of .032 you will want to cut your flap spars out of it. Then the rest of the spars will fit on 2 sheets of 4x8 of .032Dan - Scratch building Patrol # 243.
I might have the same spread sheet. It has a list of material and also shows pattern cut outs to get the most out of sheets of alum. Let me know if you need it.
taildragger@yahoo.com
Dave S. P-154David Snyder
P154
