First Patrol spar well underway! This was fun!
  • First Patrol spar well underway! This was fun!
    After pulling out my hair for two weeks with UPS trying to get my cap strips then vacation getting in the way, I was able to get to work on my spar. This weekend I drilled all the holes to final size and painted the parts with epoxy primer. Tonight I shot all of the main rivets in. I am not very good at holding the bucking bar and shooting rivets by myself so I decided to use the back riveting method that I used for the attach stiffeners on ribs. I used a 3/4" x 12"x 12" steel plate as my backing plate and installed my #5 rivet die into the plate. It would have been nice if I had a thicker but smaller piece of steel but this is what I had. I then mounted it on some wood spacers so that it lifted the spar up about 1/4" - 1/2" above the supports. I first shot 2 rivets top and bottom on the inboard side then two on the tip. I them moved to the center and repeated splitting it up in sections until I was finished. I then shot the splice plate. After I shot a few rivets, I installed a Dacron fishing line down the center to make sure things did not warp. It did not move at all. Now one to the rib attach angles and the other spar.
    This gallery has 4 photos.
    Great job. Good thought on the back rivet method. Thanks for the pixs and documentation.
    Doug
    Scratch building Patrol #254
      Nice work John! I have my first spar all ready to drill and rivet, but still double checking all my measurements. I may start drilling today.
      Barry Cole plans building serial #265 Patrol
