Guys, I am ready to rivet my first spar together. Before I do, does anyone have a suggestion on the best way to get a clean cut on the ends of the spars? I need to match cut the web to the shape of the attach plates and I also want a nice clean cut, square on the end too. Thanks!
Cutting spars to length
I used the same patterns I used to make the attach plates and the router table. Takes about 10 seconds and its a perfect match....Dave Bottita The Desert Bearhawk
Project Plans #1299
You will need to take a hacksaw or whatever and cut the vertical cut on the flange and then just clean it up with the router table….Dave Bottita The Desert Bearhawk
Project Plans #1299
I marked it with a sharpie using the spar attach plate. I then used a dremel tool with a cutoff wheel to get within 1/16" of the line. I then put the spar attach plate back on and secured it. I the used a sanding wheel on the dremel to sand to th spar attach plate, Then cleaned it up with scotchbrite wheel.John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
