Guys, I have my main spars done, finally. I am ready to start on the rear spars and flap and aileron spars. I have been loosing sleep over a problem I have, the shop I used to bend the spars could only go to 90 degrees. Does anybody have any suggestions to get that extra bend on these remaining spars? I want to get this done before starting on them.
Spar Angles??
You might need to check around to see if there is another shop who can do them. Check with HVAC companies or maybe ask around at your EAA chapter to see if anyone knows someone with a large brake.
Clamp the spar web securely. Pad one wide side of a 2x4 with felt. Get ALOT of friends. Place padded side of 2x4 against flange. Press gently and in unison to bend the flange over. Maybe sandwich the flange between two boards for more stability. I have seen this process used to tune up spar flanges moving them only a few degrees. Not sure about 10 to 20 degrees. Do not use this process in conjunction with alcohol as an unsafe condition may result.
Cheers
Patrol #30
