Rib angle rivet size at caps?
  • Rib angle rivet size at caps?
    Does the rib angles get 2- 5s and 3- 4s
    thanks
    David Snyder
    P154
    for patrol
    at the main spar
    at the attach angle
    there are 2 ad5 into the capstriips and the nose rib attach angel and the center rib attach angle
    there are 6 ad3 into the rib
    the drawing shows 3-ad4 between the 2 -ad5 cap strip rivets
    although I used 5-ad4 in between the 2-ad5 or main spar
    Stan
    Austin Tx
    • Flytaildragger
      Flytaildragger commented
      Thanks Stan why use 5 -ad4s in between the 25s ? Did you use 2 flush rivets to hold spacers
    • sjt
      sjt commented
      I had no good reason for 5 instead of 3. The correct hand squeezer makes it easy to do. (AD4 AND AD3 NOT AD5)
      There was some anti symmetry with the 6 AD3 that go into the rib in relation to the AD4 rivets that go into the spar.
      Probably the only consideration was that you try to avoid having two rivets at right angles. The squeezer has inserts for different size rivets.
      I wanted the rivets at right angles to not interfere with the squeezer set being used on the right angle rivet.
      They rivet pattern does not have to be offset by much, but the squeezer set will not fit correctly if they are at the same location.
    • sjt
      sjt commented
      While I am at it:
      Do not bother trying to make the lightest airplane that has ever been made.
      For example, The drawing shows the attach angles with 1/2 inch flange.
      That is the correct answer for the lightest airplane.
      That also takes longer to build.
      Rivets have a hole to edge distance spec. If you screw up the hole by just a little bit you might have to scrap the piece.
      If you had made it with a 9/16 flange the part will be perfectly usable if not made perfectly.
    I tried to use these but I could not do ad5 and even the ad4 needed to have extension handles
    I eventually went ahead and got this from the yardstore.com. I got 4 inch to do the ad4 rivets
    The ad5 needs a rivet gun
    The ad5 needs at least a 4 rivet gun. If you had a helper or are more coordinated then me you might not need a c-frame.
    From Bob's patrol book - he has a rough picture of a c frame
    I welded up something similar that has a few more adjustments
    d.jpgi bought this from cleavland aircrart tool
    I use 1/2 inch drill rod
    I also buy cheap stuff at harbor freight then soften them, machine them , and then harden them again
    Stan
    Austin Tx
    • Flytaildragger
      What make is that bench mount riveter?
    • sjt
      sjt commented
      I added some pictures of a c-frame like in Bob's book that I made
    r4.jpg This tool was very useful.
    Note, you have two assemble the ribs in a sequence so that the handle does not hit a rib already riveted.
    Stan
    Austin Tx
      AD5 rivet locations
      Stan
      Austin Tx
        do not bother riveting these locations -- just drill the hole
        Stan
        Austin Tx
          This is for the rear spar
          Only one of the cap strip rivets is pre drilled. The other cap strip rivet is match drilled.
          Below is example of what I was tryng to avoid.
          The rivets at the dead center are in the same location. If the attach angle was 1/2 inch the rivet squeezer would interfere with the
          other rivet in the center.
          If the holes are offset a little or the angle flange is a little more then 1/2 inch all problems can be avoided.
          Stan
          Austin Tx
            This is what I did for attach angles.
            I make no claims about it being the best way to do it. I just like to make tools. - You should see my attempt at making a pneumatic rivet squeezer. On second thought I do not want anyone to see that monstrosity.
            I break a lot of drill bits so I have 1/16 drill bits that are sawed off. I then use a jig to make holes arranged for mass producing the same hole pattern in each angle
            Stan
            Austin Tx
