Hi everyone. I had a question I was hoping someone may be able to assist with please? I'm a newbee with the Patrol so please forgive my terminology!
I'm looking at purchasing a flying Patrol that was assembled as a quick build kit, and I noticed that the flap cables that exit the wing root area into the cabin, pass through 2 fairleads that are offset
before feeding through a pulley and down behind the aft baggage compartment. Both of these cables are hard pressed against the airframe and rub on the tubes between these two fairleads in any flap position setting. Im also led to beleive the owner may have instaled larger pulleys in the aft upper baggage area. Is this typical and if not, how do you adjust this clearance from the fuesalge tubes? Cheers
