A friend of mine who has built several airplanes and has a Pipistrel motor glider suggested early on that I tape a yaw string to the windshield of my LSA for the flight test period. I have used them on gliders, but thought that the prop wash would cause inaccuracy. I tried it anyway and found that I was wrong. The yaw string works great, just as it does on gliders. In fact, the yaw string told me that the skid ball on my MGL EFIS was giving me slightly bad info, so I experimented and found that I needed to "educate" the MGL by telling it when the airplane was straight and level in the air. The yaw string made this easy and also demonstrated the amount of lag in the skid indicator in the MGL.
I first taped the yaw string to the base of the windshield, but that did not work well; too much turbulence. I moved the tape point on the windshield to just above my line of sight to the horizon, and shortened the string to about 6 inches, and that has worked well.
I think the yaw string is better than even an old fashioned liquid filled skid ball because it works instantaneously and because the string has almost no mass, it is always accurate, even in rough air. Try it; I think you will like it. Bob
