I’m sure I’m missing something here but I’ll ask anyway. I got my plans today #5027 and started building the form block for the nose rib. I’m looking at the plans and the lighting holes are marked with letters. In the case of the nose rib they are E and F. I’m guessing there is a dimension somewhere I’m missing but in the past two hours of going through these plans I’m not finding any sizes for these holes. Where can I find them?
Lighting hole dimensions
Congrats on your new plans Alan! For the Patrol I scaled the drawing. The lightning hole diameters don't matter too much but the important thing is that when flanged you have enough flat space between them for the stiffener.Mark
Originally posted by Alan View PostI’m sure I’m missing something here but I’ll ask anyway. I got my plans today #5027 and started building the form block for the nose rib. I’m looking at the plans and the lighting holes are marked with letters. In the case of the nose rib they are E and F. I’m guessing there is a dimension somewhere I’m missing but in the past two hours of going through these plans I’m not finding any sizes for these holes. Where can I find them?
I’ve been lifting dimensions right off the plans....but there is a way to cheat a little(tip from desert Bearhawk )... it’s half scale on that page... so measure it in millimeters... and double it... easy fast and hard to make an error
I used digital calipers to lift the dimension and a ruler to lay it down ...as the other post mentioned... keep in mind the stiffener needs a flat area between the holes so keep an eye on how much you flange those holes
