Picked one up locally today and just used it to clean up the edges on some 0.032" I'd cut with a circular saw. Wow! Makes short work of the saw marks and leaves a shiny finish that just needs a quick pass on the scotchbright wheel to finish.
Super Shear File
They are great files, I have been using them since they first came out, they work especially well on bigger pieces of aluminum. A tip, grind the teeth off the last 1/2" of the file so the end is smooth, your finger and thumb will thank you!Steve Busby
www.aeroliteflight.ca
