Guys... Had a hell of a day in the shop! I made the attempt to rivet the first set of rib attach angles to the spar. I started with the root rib as I figured it to be the easiest....I had to drill out two sets of rivets. I have not damaged the rivet holes yet but I doubt I get lucky a third time! So, what is the secret to getting them riveted down? My biggest issue was having the angles not stay put and end up with a gap between the angle and the spar.
I have been going at this spar for a month now and maybe ai need a break...nonetheless, if any of you have any suggestions on how to nail these down im all ears!
Thanks Guys!
Thanks Guys!
