Just wondering how you went with bending over 90 brad? i am at the same point with the same issues, what did you find worked the best in the end changing the design or hammering it over after the intial bend?
Spar bending
Hey Nick. I ended up removing the form block, although this was unnecessary. the leaf was not getting sufficient travel to bend the spar far enough - the brake is powerful enough, so for me it was about making the bending leaf "fatter". All I did was take the form block and after bending to 90 degrees, placed the form block between the flange and the bending leaf. It's pretty low-tech, but it gave me the extra travel required to get the bend i needed. One word of advice - bolt your table down! It requires a serious amount of grunt to bend the 8 foot lengths. You'll spend half your energy holding the table down. If I had to rebend them, I would bolt it down. I don't know if I made sense, but feel free to ask question to get to a solution. My spars look good.
