Strut End Bearings
  • Strut End Bearings
    In order to level my Patrol, I screwed the LH rod end bearing fully into the strut rod and unscrewed the RH bearing, quite a bit. The RH bearing currently has 10 threads exposed, above the lock nut. See photo attached.
    I recall that those bearings are quite long, but I don't recall how many threads are on that bearing. Could someone count threads on theirs, so I can determine thread engagement? I could take the assembly apart, but I figured it might be easier to ask.
    Thanks in advance!
    A 1/2 rod end has 1.5 inches of threaded shank. You have 20 threads per inch so the total is 30 threads. The thread length is directly from the Aurora Bearing catalogue.
      Wow!!! Talk about service!
      Thanks very much for that information. Now I can button up.
      I was right. That WAS easier than taking it apart!
