Noticed mention of using a fly cutter for cutting the big lightening holes in the rib blanks. From my previous but limited experience with fly cutters--- the idea of trying to
cut through thin sheet metal with one- seems really scary ! I would expect that when it starts to go through it will grab and then wad up the work like a ball of tin foil.
Not sure if a hole saw might have a similar problem........ Is there a "cleaner " way to make those holes ? Is there a superior style of fly cutter thats up to the job ?
Do yall make a cover plate that clamps down over the work and puts downward pressure on the work to prevent it being "grabbed" by the cutter ?
There must be a clean way to do it---- short of punching it somehow----
Tim
Tim
