Got my master rib form made and the holes bushed with steel bushings. Ready to copy/route the working copy of it. Thinking about router bits.
Have a 1/2 by 1/2 copy bit. I need a bit with at least a 1 inch cutter. I see rockler and woodcraft both have 3/8 dia cutter and 1 inch long bearing copy bit.
i would rather have a 1/4 inch dia. cutter but those are like 115$ ------ that just seems a stupid price. The 3/8 is like 18$. I know that the smaller the diammeter
the bit the less tendency to grab the work and run off with it.....
I have my router in a nice heavy router table. i will be bolting the pattern and the blank together with a 1/4 inch sheet to keep the boltheads off the table.
(keeping a nice flat , square surface on the tabletop.) Is there a secret source for 1/4 inch bits ? (that aernt an arm and a let $ )
Tim
Tim
