Chris, You'll notice that the arc cone angle narrows noticeably as the AC frequency increases. As the arc narrows (by increasing frequency), heat input becomes more focused. This becomes really beneficial when welding thinner aluminum. Aluminum conducts heat so well, it takes a lot of current to weld, because the cooler surrounding metal sucks heat away so quickly. With the narrow, higher AC frequency, the heat can be more focused on the joint, allowing you to weld at slightly lower current and at faster travel speeds. I find I have less burn through issues on thin aluminum, with higher frequency. You'll also notice that the higher the frequency, the smaller the 'cleaned area' surrounding the weld.. I'm sure Mr. Tig stressed the importance of cleaning the base metal and cleaning the filler rod too.
Have fun! Play with all the controls to see what suits you best.....and practice, practice and practice more.
