Does Al. cladding survive compound bending ?
  • Does Al. cladding survive compound bending ?
    I chatted with one of the local IA's and asked him this question--- but he had never had it asked either. So i will keep digging
    for an answer.
    Tim
    That's a good question!
    I'm going to go with no though, at least not on the outside radius. Cladding is only about 5% of the thickness. So, on a piece of 0.032", that's only 0.0016". I don't see that micro thin layer of aluminum stretching all the way around the bend. Also, notice that the outside radius is generally duller/less shiny after a bend. To me that's an indication that something on the surface of the metal is different from the rest of the metal.
      Steve F. :
      I am wondering if there is some type of chemical test that could differentiate pure AL from Alloyed 2024 ? Something like a weak water
      based solution that you could paint on and if the clad had parted- it might look like the Nevada salt flats...... seems like 2024 has copper
      in it I think---
      This must be known by those who make lots of parts over form blocks......
      T
