Watching the "Desert Bearhawk" channel----
He shows a place there he couldnt get the dimpler tool on the spar near the root end.
I remember having that problem long ago--- made a dimple tool. Bronze rod fitted into rivet gun. End had a cone cut into it at the proper
angle. Had a center steel guide pin (about 1/16) which fit through a pilot hole in skin. Backup block with concave "v" and 1/16 hole in center
for pin to go into. A few gentle cycles of the rivet hammer and you had a nice dimple. Drill out and de-burr to rivet size.
Anyone tried this for hard to reach areas ?
Found if I made the dimple in the skin about 90% --- and let the flush set finish the compression they came out perfectly flush and smooth.
never had to shave one.
T
T
