Having looked at various discussions here regarding rib lengths, I am tending toward trimming the ribs to length upon assembly. That means leaving them all at full length for now. But what is "full length"? The plans indicate the ribs sit TIGHT against the spar/capstrip/spacer material. Is that how it works out in reality? Or is there a slight gap in there? Since the rib attach angle is holding the two structures together, I'd think you might want a small gap as long as rivet spacing is not harmed.
Also, for measuring rib lengths, where are you measuring from? For the nose rib, from the nose at the centerline? For the center rib, can you find a point along the centerline to measure from, forward and back?
