I'm no where near the point of making the spars, but dream building in my head, reading the plans, manuals, and build sites, trying to scope out various items. The manual and The Bob Book explain to cut the spar blank the height of the rib, adding in 1/8", plus the 9/16" for each flange. Directions understood.
Looking at the pictures from various plans built spars including Eric Newton's world famous and seriously 'underpriced' builder's manual (plug-plug), there looks to be a bit of a gap between the cap strips and the top and bottom flanges, which does not appear to be consistent from one builder to other. It would make sense for there to be a variance between builders as it's based on the accuracy of the ribs, spars and wing attach plate each builder manufactures.
My question is this: Is there a tolerance level to stay within for this gap, or is it a 'do the best you can' scenario? Or Is less than 1/8" to small and may cause binding and more that 1/4" too large which could cause structural issues?
