I'm getting ready to mark and drill the ribs for stiffeners, and looking at drawing six the stiffeners all appear to be placed perpendicular to the chord line, which is difficult to draw on the flanged rib. What methods have those of you that have completed this step used to located the stiffeners? I honestly wonder if they could just be eyeballed, but I don't know how critical their placement is. I could always build a jig, but don't want to over think it if it's not that crucial.
Rib stiffener layout question
Originally posted by John Rheney View PostOne suggestion: look at where the stiffener leg (perpendicular to the rib web) is in relation to the rivet locations for riveting the skins to the ribs. You can flip the leg to be either left or right to avoid blocking your bucking bar later on.
Originally posted by DRLPatrol View PostDon't forget that the rear stiffener on 2 of the 0.032" mid ribs in each wing are also the attach bracket for the false spar. They are 0.32" and location is critical. Don't ask how I know.
Doug
That should work.Or lay a false rib up against the mid rib and that will show you where the false spar will land.
Doug
OOPS; Just noticed that this was in the 4 place section. I am building the patrol but I guess it still applies.Last edited by DRLPatrol; 02-26-2015, 11:12 AM.Scratch building Patrol #254
