Guys,
Working on getting my flight controls (flaps) hinged up. I am concerned about getting the hing line perfect. Because there are 3 hinges if they are not lined up perfect you will get a bind. I've located my steel as best I could but they are not 100% perfectly lined up. My question is how critical is it to have them lined up spot on? Can you make adjustments by sliding the rod-ends in or out?
What is the procedure you used to get everything lined up correctly?
Thanks!
Thanks!
