Hi there it would seem to be the case that there is a lack of structural information regarding the plans for the 4 place Bearhawk in order to qualify for the utility class and acceptance under the reg EASA cs23 and old Bob doesn't have the information to give at least I have asked and he has not been forthcoming, I can see that there have been several plans sold to people and this is evident on the Bearhawk builders map has anyone else been able to register the 4 place and has anyone payed for the structure tests in order to pass the dossier. To build I'm planning to build the Bearhawk as a two seater and use the space as large storage for two small electric push bikes so perhaps it will be accepted.
Plans not acceptable in Europe EASA cs 23 utilities class
Hi George,
I reside in Germany. Building experimentals im Germany is based on national regulations. (like Annex II listed planes too ) and not under EASA regulation. Basicly it is possible to build an 4 seat experimental, but I have to confirme a lot more details during building and spins tests during flight approvement. Building as an 2 seat plane gives me a lot of facilitation. Nevertheless the way to go (4seat/2seat) I have to do a wing load test or structure tests with 3,8g for normal category or 4,4g for utility category. Additional I have to calculate the structural strength.
I can imagine, depending on where you build, it could be the same regulations.
Ralf
