" I installed a dual panel mount USB I got from Commitlift.com. They are located in Sisters OR and take up just about as small an area on a panel as possible. The web site is very informative and worth a visit. Lots of informative info on USB's and how they work. Nothing wrong with a cig lighter, have one of those too"
I had the opportunity to use the Commitlift USB port yesterday and it works as advertised--a really fast charge. This is way better than the cig plugs. They appear to be more of a trickle type charge, where as this one is super fast. D.
Panel Talk
OK, I recently found out that the Grand Rapids Tech. Sport EX and Mini X can both be used as a "tuning head" for the TRIG TT22 transponder. They indicate that is a $500 savings. I like that!
Leave a comment:
Here is the current state of the panel. We didn't get much done for a while. I had to work down in Texas for 3 weeks running and Brent took time off for a knee replacement. He can be such a whiner! As if an operation should slow him down!!
Anyway here is the latest. We got the basic wiring done and we got Brent's prototype "Relay / Fuse Box" installed and working. Please note we had to add momentary switches to the panel below the fuses. The LED lights at the top of the box light up when the switch is powering the circuit. The fuse is in line with switch and LED. The white buttons at the top are just programming buttons. Yes, I did have to learn how to program the box!
Leave a comment:
We just added the cigarette lighters as a way to add power. I guess we could also add the USB but I think one is as good as the other from my standpoint.
Leave a comment:
Originally posted by Flygirl1 View PostEric, taking a closer look at your panel and noticed an engraving in the center. It looks removable. Is that an access panel? And LOVE the bear hawk!! D.
Leave a comment:
Had to laugh at your comment about getting panel ideas from the Citabria... I guess am too, but mostly "things I do NOT want to do..." Of course, mine is a '65 7ECA, so they may have gotten more "ergonomic" since then. My "mixture" and "cabin heat" knobs are identical (unlabelled) chrome knobs. The mixture knob is on the far left, and the "cabin heat" knob is 1.5" to the right of it. The label for the mixture is black, and the cabin heat is red... Talk about counter-intuitive, when you're used to leaning with the "red knob"...
About the only thing I'll carry over directly is the idea of having a "pencil shelf" in front of the panel.
I really like the clean, simple design of both your panels. And I am definitely "stealing" the idea of putting things in "start sequence". That just makes an incredible amount of sense. Great job.
Jim, these panels are missing the carb heat and cabin heat push pulls. The holes are started though. Also we have red led's under the glare shield which is not in this photo either. A note on the glare shield-- We sprayed a light coat of flex seal and it looks great. Gives it a bit of texture and I think it will stand up to the sun. But I have to admit I covered it up with black shelf stuff. Not sure what it is called. Keeps your plates from slipping around. The curve on the Patrol panel didn't allow me to set things up there. The shelf stuff does the job. D.You do not have permission to view this gallery.
Leave a comment:
Leave a comment:
Originally posted by JimParker256 View PostLooks very clean and neat. Love the integration with the Dynon Skyview systems. What did you use for the "wood panel" look?
I get the L Mag / R Mag switches, but what do the two PMag switches below them operate? I would have thought a single "on/off" switch for each P-Mag would have been sufficient. (But I'm still early in my P-Mag research.)
Also, I'd love to see a full-width picture (or series of pictures) showing your entire panel layout. Mine plan is somewhat similar to yours, thus far.
All our circuit breakers are underneath on the side as is my parking break and mixture control. Also my headset jacks are on the other side underneath beyond the mixture control. this allowed me to run my headset wire under the side panel so when you look at it there are no visible wires!! I hate wires hanging out all over stuff.
If we would have chose the e-mag instead of the P-mag we could have used one on/off switch. The P-mag has an internal alternator/generator in it. It powers itself after a certain RPM is reached. The P-switch, (white one) or AKA Power switch, allows you to shut it off once your at 900rpm or so and check it. They are explicit on start up and shut down procedures so having it in the necessary order will keep me from doing it wrong until I get used to the system. These little gems also require a simple air blast to set the timing and "waalaa" your done. that simple!!. Can't wait to fire them up. We have had freezing fog for days now and haven't been able to even start the engines. Hoping tomorrow afternoon this will clear enough to get it done. I have over 3000 photo's and I can't find the darn thing and then my card keeps messin up, but will post a photo ASAP.
Leave a comment:
Designing the panel, for me anyway, was by far the most fun part. I moved the little stickies every day until it was just the way I wanted it. My method of madness was electrical on the left and starting on the right. The starting sequence was important because I've never used a system like this before--dual electronic P mags. So everything is in the order of use--up the stack to prime, power to mags, (un)ground mags, start, radio's and visa versa to shut down. D.You do not have permission to view this gallery.
Leave a comment:
This is the usb in comparison with a dime.You do not have permission to view this gallery.
Leave a comment:
I believe the guys discussing this on the AeroElectric list are pretty confused, and the CommitLift guy has it right. His analysis agrees with what I see from my Anker 40-watt 5-port charger, which charges my iPad Mini 4 even faster than the Apple wall-wart does. I don't believe it's voltage on the "other" pins that controls the charging rates, but the differential voltage he talks about on the primary pins. Re-read his document and see if that doesn't make sense given the instrumented readouts posted in the article. Seems like he figured it out correctly to me...
I'm betting $150 on his design (one for the front and one for the rear seat), rather than try to fudge one up for myself. It would take me a LOT more time to design / build my own, with no telling how many false starts along the way. I'm thinking I'll mount the front USB plug to a 2 1/2 inch standard instrument cutout "blank" on the panel so it's easy to access for service. The device is 2 1/4†wide x 1 1/8†high x 1 1/2†deep, so they should fit the 2 1/2" opening just fine.
But I'm also "future proofing" by adding cigar-lighter style "aux" sockets. I'll put 2 in front (one on each end of the panel) and 1 in the back seat area. I'm also going to put one accessible from the baggage compartment so I can plug in my B-Cool ice-water "air conditioner" on hot days. That one will be wired to a switch (or pullable circuit breaker) on the panel for "on/off" control. Hopefully I'll be prepared for almost anything at that point. And if not, well, I wired it once, I can re-wire it if necessary!
Leave a comment:
Leave a comment:
