Got all my nose ribs done. Seems clear NOW --- that when it comes time to attach the nose ribs to the front spar with the attach angles---- I imagine I will stretch a wire down the wing
with the wire running through the front jig pin hole---- and adjust the exact position of the wire to match the hole position on the mylar master template. That should assure that the nose
ribs are in the correct position and duplicate the shape of the master form.
NOW--- I am making the tooling blocks for the main center ribs. I see that the mylar master form shows NO jig pin holes on that rib. I BELIEVE I need to make two 3/16 holes in the
diagonal corners to function as jig pin holes for the big rib. I will need those holes ALSO when I hydroform them to prevent the sheet from sliding on the form during the pressing.
Seems like the holes could also perform the same "locating" function later when riveting them in.
I have looked at other peoples center ribs and see jug pin holes at the diagonal corners. (N3UF- mr. Snap in his video)
Does this sound logical ? I guess I will have to drill 2 additional holes in my master form and transfer them to the cutting jig and forming blocks. Does this sound right ?
Tim
Tim
