Page 3 questions
  • Page 3 questions
    The drawing called.... wing rib.... is the actual size of the finished rib including the flange
    is the page 7 drawing .050 smaller to account for the flanges on the top and bottom already taking this into account?
    I'm wondering out loud if others have made thier formers slightly smaller to account for the .025 thickness of the flange? But leave the nose area untouched since it has no flange to account for. Sort of a long joggle...
    The reason I'm asking this is because if the flange width is not accounted for then you will have flat spots running along the leading edge of the wing top and bottom....full length of the wing...not big mind you...probably 1/4 inch wide
    does the factory do the joggle on the central ribs for the main spar to nestle into, I watched thier video and it appears they don't, but it's hard to tellI've heard on here it's optional...on average how many builders do their joggles?
    No need to overthink it. Cut your Mylar to the line or maybe slightly through it and roll wth it. You’re making parts for your plane and no others. So your master will be right for everything on your plane.
      I took the Mylar drawing to Office Depot and had them make a print of the drawing full size.. I then glued the print to a piece of 1" thick, hard maple wood. I then cut right on the line. That was the master for forming the ribs. And I used that master to form the reinforcing pieces above the main fuel tanks. Having the details from the Mylar on the forming master was very useful.
        My factory Patrol wing has the center ribs Joggled to fit up under the main spar's flange.
