Hi,
I am preparing to match drill my wing strut attach bars at the main spar splice plate. I am planning to drill under size and then ream to get a nice fit.
I plan to order the AN-4 fasteners from Aircraft Spruce, but I don't know exactly what should be used.
1) Where should flat washers be used? only under nut? none at all? (this affects the length)
2) What type lock nuts should be used? nylock? (elastic stop nuts)? safety wired castle nut?
Thanks,
Thanks,
