There are no dimensions in the plans or the builders manual. I understand that some parts will need to be scaled up, but there is no number to scale to on the plans.
Lightening hole sizes
I do not have my drawing in front of me, but I believe in the lower right corner it states Scale 1:2. Which basically means the items not showing a dimension or do not state "drawn full scale" are all drawn at 1/2 the full scale size. Therefore you would measure the diameter of the drawn lightening hole and then double that measurement to have actual full scale size. I hope this helps.John, Naples FL
Bearhawk 4-Place Plans #1316
Patrol Plans #006
