I am currently planning on beginning work on the main spar but I have some questions that I had hoped would have been answered studying the plans, but the more I read them the more confused I am about them. Specifically, there is a dimension titled 'length of spar web to splice' that appears visually to be longer that the spar web section itself, going from the splice point to the tip of the wing attach fittings. Is this an incorrect labelling or an incorrect drawing? If it's labeled incorrectly, how do you get an absolute for the width of the spar web? I can infer it inexactly based on rib spacing and combining a few other measurements with the distance from the center of the attach fitting hole to the attach fitting tip but I feel like I'm missing something very obvious here about sizing these cuts, given dimensions were given explicitly for all of the spar caps.
Also, each of the spar caps and attach fittings appear to have octagonal cuts at the end as opposed to a more circular profile. I know those corners can have a tendency to act like a punch against aluminum sheet, so I have to ask, are they that shape for ease of cutting/assembly and a more rounded profile would be preferred, or is that shaped that way for a reason?
