Hari. I made my own tool. I have a lathe, machined some 1/2" brass hex stock to 3/8" diameter brass to just fit inside the fuel line. Drilled and tapped a hole for a 1/4-28 tpi bolt. Took the bolt and ground a taper at the end. Drilled a hole to intersect the tapered point. Hole just slighty smaller than a bb. Slips into the tube, edge butting. As I tighten that inner bolt, forces BB to create the bead.
