Hello,
I am building a QB Bearhawk in Texas (Sherman - north of Dallas about 60 miles). Fuselage is QB #99. I am at the point of adding lead to the elevator. I understand the process and see no problems accomplishing the task. Only question is, how much? I have read and re-read the sections about calculating the exact weight based upon estimated fabric and paint weight. However, it seems like there should be a number (pounds) that can be used which would accomplish the counter balance requirement. I was planning using 2.2 pounds per elevator tip. Would that number accomplish the task? I don't want to purchase actual fabric until I am completely pre-assembled and ready for cover and determining the actual square footage of fabric based upon the curve of the elevator is higher math that I took in college.... LOL. From other posts, it looks like actual weight is not absolutely critical as long is the counterbalance weight is close. Any ideas?
The forum is a great tool and as a builder, I appreciate eveyone taking time to answer questions and share ideas. It really helps those of us that are "Assemblers", not "Engineers". I can put anything together, just can't design it worth a flip...
Thanks,
Thanks,
