I purchased this nice looking Beringer park brake valve. When I got it home I noticed the installed nipples (the silver ones) are -3. I am using 1/4" tube with -4 fittings on the rest of the system. The question I have for you folks is can I run 1/8" tube from the park brake to the top of the gear legs and use 1/4" on the rest?
Park brake valve
Park brake valve
I purchased this nice looking Beringer park brake valve. When I got it home I noticed the installed nipples (the silver ones) are -3. I am using 1/4" tube with -4 fittings on the rest of the system. The question I have for you folks is can I run 1/8" tube from the park brake to the top of the gear legs and use 1/4" on the rest?Tags: None
[QUOTE=SimonNicholson;n32009
. The question I have for you folks is can I run 1/8" tube from the park brake to the top of the gear legs and use 1/4" on the rest?[/QUOTE]
My opinion is yes. No problem. I might even be tempted to run -3 for the whole brake system.
Originally posted by Ed Welfred View Post. The hydraulic fluids job in the brake system is to transfer pressure. There is very little fluid movement.The diameter of the lines and fittings are not an issue in a brake system. The exception is while bleeding the system. Ed
